Originally Posted By: motor_oil_madman
How are you supposed to know how much grease is in the hub if nothing comes out?
Good question ..... hmm ...... that's tough to respond.
Even tougher to implement or comply with.
Here is my 2 cents.
In a new assemblying works :-
Firstly ,I would refer to owner manual , if you happen to have one, which would rarely provide any quantitative indication.
Secondly I would guesstimate/calculate ,with some steel-rule measurements , amount/volume of bearing housing assemblies.
Thirdly , I would hand-pump say 80-90 % of above calculated volume , while observing if any grease is oozing out from inside .... and stop greasing immediately if oozes is observed and noting cubic centimeter in question.
Lastly ,
measure and compare temperatures (with IR meters or human fingers if measuring tool unavailable) at external housing closes to an inner/outer bearing location , on first day of operation , and make adjustments accordingly.
For general bearing application , any maximum bearing housing operating temperature below 50C is normal.
On eccentric shaft bearing housings on a rock crusher that oozes during regreasing, I've measured as 60-70 C and it drops to 50-56 C after skipping 'numerous' regreasing at regreasing intervals recommended by equipment manufacturers.
Note: My ambient is 33ish C.
