I have searched the forums and found topics of thick sludge in the diff, but it's usually associated with 4 wheeling in high water. I drive a rear wheel drive dodge dakota and NEVER go through water. I had drained the stinky dino gear oil when I got the truck with 120,000 miles and refilled with valvoline synthetic 75-90, at the time I had cleaned out the bottom of the diff and refilled. Now at 170,000 I once again drained the fluid and the goop is in there once again. Is this normal? I never tow or drive hard and stay off of dirt roads. I hosed everything down with brake cleaner and refilling with castrol synthetic. Is there anything I should do to help keep the differential running cleaner and not having this sludge left behind? The fluid drained out perfectly clean so obviously the sludge does not stay suspended in the gear fluid. It's possible the valvoline mixed with the old dino residue to make this sludge, but still if there is a way to keep everything clean I sure would like to know!!!
