3000gt vr4 sputters at 3000rpm
Cambridge, Minnesota
My '93 3000gt vr4 sputters at 3000rpm, car feels like it has no engine power, car jerks and shakes until you let off the throttle. But...if you pin the gas pedal down it accelerates like normal. It does it in every gear, and neutral, but much less while in neutral. Any ideas???
First off clean your throttle body. Second clean your MAF sensor. Third check tps sweep with a volt meter and make sure there is no diectric grease or other contamination in the connection. I would also mention vacuum hoses n such but you should notice it more at idle than 3k rpm.
Edit: i should mention that what you are looking for when you take that meter to you tps is a smooth and consistent change in resistance. If you see a deviation or drop then you know it is bad.
