Rod bearings do have more clearance at the parting line normally. The reason being the rod and cap distort and close up the parting-line clearance at high RPM. Real olde tyme engines had shims at the bearings and it was relatively common to re-ring an engine, lap the valves and take shims out of the bearings to keep it going.
Knowing the position of SWMBO makes not pulling the engine understandable. Thankfully my marriage is considerably different in this regard. I got exactly zero grief when I brought home my '64 Avanti in "kit" form. She makes more money than I do and it's my money I'm playing with. At least I got this right the second time around!
