I really like Subaru engines, but either the Honda or the Robin may not work in my application. I have a light knock in the Briggs and this is for my Trac Vac 880 so I would need the impeller and the impeller housing to mount to the engine. I'm pretty sure the impeller/shaft is 1" diameter, then I have the mounting holes to contend with for the housing.
This is a real strong running 8HP, one of the better engines I've used so maybe it's worthy of a rebuild.
What are your opinions?
The Briggs is a:
Model: 192432
Type: 1189-E1
Code: 0005291A
The Briggs is a:
Model: 192432
Type: 1189-E1
Code: 0005291A
