I use AAP's promo codes a lot. I constantly come up just short of a great discount. I know about the cotter pins lol. But what I am trying to do is come up with a master list of everything under $5. If you are more than $5 away, there are MANY things that people need, so $5 is a reasonable limit (I think). And I know, under $5 is a BIG list... I'm willing to make it if you guys give ideas/links (links to ANYTHING are MUCH appreciated). No, this won't be done tomorrow, but this could help a lot of people in the long run. Especially if I sort it into categories (under $1, $1-$2, $2-$3, etc., or by item type). It could also give this site a lot of tourism. I will definitely make a separate thread with the end result (giving credit to all that help). Constructive criticism appreciated. Thanks in advance. Keep the ideas coming!
So far here is what I have thought of:
Cotter pins
Nuts/bolts
Cheap oil filters
Valve stem caps/hardware
Cheap spark plugs
Small bottles of additives (MMO, Lucas, etc.)
'Counter grease' (brake pad, spark plug, bulb, etc.)
Various light bulbs
Brake fluid
Brake cleaner
Washer fluid
Power steering fluid
Cleaner products (Armor All, Turtle Wax, etc)
Cotter pins
Nuts/bolts
Cheap oil filters
Cheap spark plugs
Various light bulbs
Brake fluid
Brake cleaner
Washer fluid
