Relevant, It indicated a oil high temp. polymerization resistance and as oil are liquid a boiling point would be around 280'-320' C.
Speaking of temp, you can see edge of a piston reaching this temp. Or latest BMW 4.4. twin turbo, has a very high thermal design. testing it on bench is disastrous wire and plastic melting, need a significant cooling option; using bad oil in this engine would be catastrophic. Don't compare it to clunky Toyota - this one indifferent to any oil.
