The mechanic also inspected the tires and raised the car and checked front wheel bearings. Wheels have not been balanced for at least 15,000 miles.
Steering wheel vibration was putting my arms to sleep. Increasing TP from sticker 32psi to 37psi has cured that but the steering wheel still shakes a little. Do you think sticker recommended TP is usually too low?
The mechanic didn't even suggest balancing. The trip to the shop only cost me a $3 tip. At this point I have saved $22!
