Originally Posted By: philipp10
Originally Posted By: CT8
I have well water, I use distilled water. The mineral deposits on the plumbing are amazing.
true you can build up some serious mineral deposits in a sink, however, your sink is bombarded with fresh mineral water with EVERY use. You radiator, being flushed and changed out every 50k miles would only see fresh minerals 4 times in a 200k mile life. Not saying to use tap water but am saying that it is hardly comparable to your sink.
Good observation. "Distilled" is easy to come by from a dehumidifier, but I use well water, hard or not, the only reason I changed the radiator on my 330K miles Camry was a crack in the plastic tank at 275K. I run a 50/50 mix.
