Originally Posted By: bonjo
great info busy.
there are a couple of ???'s in the back of my mind which stop me from using 10-40. I have been using FS 10-50 all the time instead of 10-30 recommended by honda
what happens to oil degradation and loss of VI over time. say for a FS oil (like motule or mobil) after 6000 miles, starting with 10-40 or 10-50?
what is 10-60 recommended for off road bikes?
how does thinner oil affect gear change and oil consumption?
You're welcome bonjo...
My experience is that Honda can be trusted... if they recommend in
writing a 6K oil interval then it will meet and exceed your mileage
expectations because I believe after talking with the engineers at
Honda that they do thoroughly test the oil... in fact it doesn't
matter to your engines longevity if you run Dino or Synthetic... or
even 50 40 or 30 weight.... no one is wearing out their engine... but
it does matter in the amount of rear wheel HP is wasted in unnecessary
oil drag... between a 30wt and 40wt is 2 to 3 HP in unnecessary oil
drag... between a 30 and 50 is 4 to 6 HP in unnecessary oil drag...
choosing the freest flowing viscosity of 30 as prescribed by the
official Honda manual over a 40 50 is smarter because it will:
1)increase HP at the rear wheel
2)quicken the throttle response coming out of the corners...
3)decrease over all operating temps...
4)increase the oil flow at the critical bearings...
My customers report no negative difference in gear change or oil consumption running the recommended 30 weight...
After 25 years dealing with customers on this subject I found its not
a question of oil so much as a question of foot technique and clutch
drag... its a fact if your clutch is part way engaged your gears will
not shift smoothly as designed... here's how to check your clutch for
drag...
1 Place your bike on the center stand...
2 Start engine and establish a steady idle...
3 Squeeze in the clutch and hold... shift into first gear...
4 Now look at the rear wheel... if it's spinning step on the rear brake...
does this action drag down the engine rpms???
If you bike is equipped with an cable then adjust the clutch lever
knob clock wise (out) 1/4 turn and check again check for clutch
drag... if you bike is equipped with hydraulics bleed system and check
for bubbles...
Ultimately you want the rear wheel to stop when the engine is idling
and first gear selected with the clutch lever is squeezed in...
Makoto San my retired HRC engineer friend...
Makota San down on cannery row...
