Originally Posted By: jmsjags
If you are buying a premium oil filter like a Fram Ultra, Purolator Synthetic, Mobil 1, etc. and changing it every oil change, the bottom line is you are throwing away money. You do not need to be buying extended drain filters if you are not using them for their intended purposes.
I buy synthetic oil and Fram Ultras. I change the oil every 7,500 miles, and the filter every 15,000 miles. If there is residual oil left in the oil filter every other oil change then so what? The oil can go 15,000 miles anyway, and my oil filter will now be more efficient for the last 7,500 miles.
With a fumoto valve, I only have to get my hands dirty EVERY OTHER oil change. It's amazing, you should try it!
If you know your oil can go 15,000 miles and you change it every 7,500 miles, aren't you throwing away money too?
Originally Posted By: ZeeOSix
Originally Posted By: SilverC6
OEM Toyota filters are very efficient.
I wouldn't call 51% @ 20 microns "very efficient". Maybe compared to no filter or a fine door screen, but certainly not when compared to others on the market.
http://www.amsoil.com/graphs/eao/EAO_efficiency_900.jpg
There is no documented evidence that a more "efficient" oil filter will make the engine last any longer.
Old VW Beetles from the 60s are still running around and all they had was a cheap screen, no oil filter.
