2011 Subaru Impreza NA - 50394 Mi - NAPA 5w-30 Syn
NY
First analysis for me, but from what I can tell the numbers look pretty good. Ran the fill longer than I wanted to/usually do, but doesnt look like it hurt anything. No makeup oil, Subaru OEM blue filter.
Code:
OIL NAPA 5W-20 SYN
MILES IN USE 6,208
MILES 50,394
SAMPLE TAKEN 9/21/15
ALUMINUM 2
CHROMIUM 1
IRON 6
COPPER 1
LEAD 0
TIN 0
MOLYBDENUM 44
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 10
SILICON 7
SODIUM 298
CALCIUM 2150
MAGNESIUM 19
PHOSPHORUS 595
ZINC 730
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 395
SUS VIS 210ºF 58.8
cSt @ 212ºF 9.88
Thoughts?
Is this an FB or a EJ?
Looks OK, though many typical constituents seem underrepresented.
KNOW this: you will never see impending sliding/rubbing/ component failure macro wear in this UOA.
I recall there being no moly carbamates in NAPA SYN. Did you use an oil that has the Infinuim premium package as a component previously?
Or, possibly, der !VERBOTEN! LiquiMoly?
GASP
Engine is the 2.5L EJ, Naturally Aspirated.
I honestly dont know too much about the previous oils that were in the car, since its relatively new to me (only a year old). I do know it had some PYB in it prior to the NAPA Syn, but that was for a 5k mile stint, and thats all I know. The changes before that are a mystery.
Current fill is Pennzoil Ultra Platinum 5W-30, Subaru OEM filter. Will post a UOA afterwards to compare between the two.
Also want to clarify it was 5w-30, not 5w-20. Can't seem to edit it now.....
