Originally Posted By: fdcg27
Over the last couple of atypically cold winters, our daily drivers saw a lot of warm-up idling in the drive.
You'll do that on a The one with an IOLM, the '12 Accord, could account for this.
It still showed 15% MM after 7K+.
This is in contrast with the 9K+ you'll see under ideal conditions.
So, I conclude that idling and cold weather starts may reduce oil life, but not to something silly like 3K.
Since I change our vehicles without IOLMs at 5K-7K, with the longer drains on vehicles that see a lot of steady speed driving, I'd say that my engines are okay.
Your engine would be as well.
As an old member from CA whom I haven't seen here recently used to post, the car serves you.
I agree. Reading some of the comments on here, seems like a lot of people are not opposed to extended OCIs, but only under the most ideal conditions. Once you deviate any way from those ideal conditions stick to 5k because oil is cheap is the advice I am hearing a lot.
For people who never change the oil, the engine gives out after going ~50k on the factory fill. Makes the debate about 3k or 5k extra on your oil seem somewhat silly.
