Last week I had the driver's side CV axle replaced in my Sedona, twice. The first one had a sloppy outer joint, causing vibration when accelerating, so they replaced it with another one. At the same time, I had them change the oil since it was needed. However, when in second gear from about 2,000-2,500 rpm, I feel a slight vibration in the steering wheel. It's less pronounced than the first bad axle, and goes away at all other RPMs, even under heavy acceleration. I noticed that they also overfilled the oil slightly. I did a test today and put it in park and raised the revs to that same range, and I also get that vibration in the steering wheel. So in gear, or in park, those vibrations are still there. So, two things...
1) can an overfill cause a rough running engine?
2) maybe the original bad axle (before the two replacements) was covering up vibrations because it had so much play in the inner joint?
Motor mounts and other bushings are all in good shape.
