Quite common on "First year" 2007 fullsize Trucks & SUV's.
Clean throttle body bore, Most likely this will cause a high idle situation, That sometimes will not go away (The ECM will not relearn a new closed throttle position parameter)
Using a Tech 2 (other scan tools may work, I am not sure)
Lie to the scan tool by selecting a 2008 Tahoe, Select "special functions", Then select "Idle Relearn".....This is around 85% effective. The other 15% need new throttle bodies & the latest software update flashed into the ECM.
