According to Consumer Report Tread Life Warranty are Next to Useless.
From my experience with local AT in Orange County, Southern California, all points in this article are inaccurate/wrong.
I had tread life prorated for Continental DWS toward purchasing Kumho 4X 2-3 years ago, tread life prorated for Kumho 4X toward purchasing Cooper CS5 last month.
I didn't have/keep receipts of rotation, tread wear were uneven with 1 tire at 2/32 while other 3 at 3/32.
At the very least, AT(DT outside So Cal) was very easy in tread life warranty claim. I will stay with AT as long as they have stores in my area.
https://www.yahoo.com/autos/why-tread-life-warranties-are-next-to-useless-220442995.html
Quote:
Moreover, if the tire doesn’t live up to the wear promise, you may find that the so-called warranty imposes so many restrictions and conditions that it’s nearly impossible to collect on. It may even be pointless to try, although a diligent and truly determined consumer can sometimes manage it.
With tires, that credit is usually good only toward the purchase of an` essentially identical tire from the same manufacturer. If you didn’t especially like those tires, and maybe wanted to upgrade to something better, tough luck. Then you get nothing.
Your credit, though, is applied to the standard retail price, not any discounted price you may find. And tire discounts are very, very common. So, as a practical matter, your credit may be worth nothing.
Before a retailer will even consider granting a mileage-warranty credit, you have to fulfill some pretty exacting requirements. These may vary, so read the fine print.
You have to have kept your original receipt, with your car’s odometer reading at the time of purchase, and whatever warranty papers came with the tires.
If there was a recommended tire-rotation interval, say every 5,000 miles, be ready to supply written documentation for each of those services.
The wear must also be absolutely even across the tread. If your tires ever got misaligned, or were under- or over-inflated so the wear isn’t quite uniform, there goes the warranty.
All this has to happen within a specified time frame, say four or five years.
