how do you avoid breaking exhaust manifold bolts? heat them up cherry red and them wrench them? some other trick? this question is regarding two different cases:
1) removing bolts from cast iron heads (especially really old ones!)
2) replacing the exhaust manifold donut gasket from my Echo. most DIY'ers seem to break the bolts off and have to pull the manifold and re-thread...
