2009 G8 GT 6.0L L76
I have a small amount of knock showing up at low throttle positions and low load. It does not appear to show up at high throttle positions, and I'm not sure but I don't believe at higher RPM's.
The car has 85k miles and is in good repair. No real aftermarket stuff or power ladders except a solo exhaust. No change in knock before or after the exhaust was installed.
I see upwards of 6 degrees retard at times when running 87 (the factory recommendation) and @.5 to 2 degrees on 93. That leads me to believe it's a 'real' knock retard.
Any thoughts on chasing this down?
