Hydrotex Hy Diamond 6Kp and corroded bearings
Kestas
Staff member
The Motor City
I have a client that is corroding his bearings. The bearings are reportedly lubricated with Hydrotex Hy Diamond 6Kp using mist oiling. Is there anything about this fluid that is caustic? I suspect there are some caustic chemicals contaminating the lubrication area. I just want to make sure that Hydrotex Hy Diamond 6Kp hydraulic fluid isn't caustic itself.
That's sold as a "compressor fluid" not considered an industrial lubricant? Seems an odd choice of fluid for that duty.
Rand,
note that it's mist lubricated, a "mist" of oil is carried into the bearing through a stream of compressed air...it's not that strange a lube when looked at that way.
Kestas, is their air drying equipment up to scratch ?
No dead legs storing water ?
As usual, the information I'm getting is third-hand, and the final user is out-of-state. Both comments above are helpful. I'll give more information as available.
Hello,
I am the Hydrotex area manager for lower Michigan. I would like to speak with the person having the problem. Our staff is very capable of helping solve this problem, but we will need more info. Please contact me. [email protected] or by phone @ 616-902-0704. Thanks.
I finished my investigation and find the bearing failures are completely unrelated to the lubricant or corrosion. I couldn't get much information from the client because the bearing is used in a proprietary process. I do know it was used in a high-temperature application, which is likely the root cause for discoloration of the bearings. I appreciate ukeyowl for availing himself to help in this matter.
