Originally Posted By: Nissan101
Hi i want to replace the stock yellow ID plate light with the white/blue light(Light that resembles HiDS)....is it a special LED bulbs that i can use?
THANKS
That blue white may be "kuel" but better LEDS come closer to pure white. Superbright LEDs.com will show you the color of their offerings and you can usually pick from white, "warm" white, and the ricer "blue white" light. Inexpensive LEDs in white are usually a BLUE LED with a coating which emits a white light when hit with the blue. It always says "cheap bulb" to me. There's nothing worse that a fast blinky blue white turn signal. BTW check to see if your car uses a "CAN buss" for lighting control. The bulbs need to be set up for it. Post 2000 cars usually have it.
