I agree that the spectacularly bad problems of GDI IVDs (and oil loss) were very much an Audi 2.0L TFSI thing. Poor VAG. They do seem to have lost the plot in recent years!
I spent a lot of time trying to understand the Audi TFSI problem. I had theories but I never quite got to the bottom of what was so badly wrong with the original piston rings and how Audi modified the rings/piston/con-rod assembly to cure the problem (which they undoubtedly did). Given that Audi tend to specify extremely high quality synthetic engine oils, I can't quite believe they had problems with ring stick (and more especially stuck oil control rings). I sort of concluded that they had put in low friction rings that were just too thin or had too low a tension rating.
Did anyone on BITOG ever truly get to the bottom of this and if do, might some kind person point me in the appropriate thread?
