Originally Posted By: turtlevette
You take things too literal. Use your filter. Energy conversion can't exceed 100%. Come on. You assume equal conversion rates. Ethanol ends up being higher because you can lean it out at cruise and get better efficiency. It runs cooler so it can be run leaner. I got about the same mileage using e85 in the vette. I believe many observe higher mileage than what you calculate. Here we go again with your formulas from engineering tool box. Things are not as straightforward as you think.
I was using the energy of a tankful as a starting point...that's sound.
I linked to an Aussie test where they drove the same roads with gas and E85 (and E10)...you ignored it.
Here's an American test.
http://www.edmunds.com/fuel-economy/e85-vs-gasoline-comparison-test.html
26.5% worse mileage, on a dedicated flex fueler. 22% more cost per mile on E85.
Here's the Government's take on it...
https://www.fueleconomy.gov/feg/flextech.shtml
15-30% depending on vehicle...I can get the 15, due to the factors that you state, 30% plain old dumb tuning that can't take optimum benefit.
I looked at the Ricardo documentation (which was what I was looking for in the first instance), they claim "diesel like efficiency"...efficiency being energy output over energy input, then clearly even the Ricardo miles are limited to a percentage of the energy content in the tank...less energy in tank and same "diesel like efficiency", equals less miles...clearly.
But, you are the turtle...and if your corvette gets as good or better MPG on E85, then you need to talk to GM, the Government, and especially Ricardo (some of the greatest minds in IC engines)...you, my boy are going to be very very rich.
