Interesting post I found:
http://www.vitalmx.com/forums/Race-Shop,42/More-expensive-premix-better,1282745
"More expensive premix, better?
A common question I see a whole lot is, "Just because a premix is more expensive, does it mean it's better?". It is easy to sit on the keyboard without actually doing any tests and making an answer up on the spot, but I decided to take it a step further.
The oils I decided to test were, Amsoil Dominator, Maxima K2, and a cheap oil known as Lucas Semi Synthetic.
Certain tests I did were, Run quality in the bike (Drained tank and ran the premix for a full tank, never opened top end up)
Hot pan test and a Flow test, and here were the results:
Cleanest burning (Least amount of smoke & Spooge at 32:1)
Lucas
Maxima
Amsoil
Hot pan test (Flow away from the hot spot or stay on it)
Maxima
Amsoil
Lucas
Flow test at -10C:
Lucas
Amsoil
Maxima
Flow test at 100C (What one was the thickest):
Maxima
Amsoil
Lucas
the stick test. Cold metal parts, could it stay stuck to the product or drip:
Maxima
Amsoil
Lucas
Hot metal parts:
Maxima
Lucas
Amsoil
How well they mix:
Maxima K2
Tie between Lucas and Amsoil
So there are just some experiments I did when I got bored, weather or not they help I just found it fun to do and definitely was surprised at how the Lucas Performed. Maxima K2 is what I will run!"
