Originally Posted By: pbm
We all understand that 0w20 and 0w30 are better in -30* weather but my simple question is...does 5w20 perform as well as 0w20 in my climate where 0*F is the coldest expected? How about 5w30 compared to 5w20 in the same situation?
There's two things at work there.
First is the ability to get oil to the pump, that's the MRV spec. If the oil is pumpable, the pump will shift the same volume per revolution regardless, and push the air out of the galleries at the same rate...should be no difference...
But if it's marginal, it will still be viscous in the galleries, and could cause some of this oil to be returned to the sump.
Here's a chart I lifted from a paper. RAOT is the time for oil to flow out of the rocker arms on this engine, this test. FOPT is Full Oil Pressure Time.
Looking at the shortest of the times, would indicate that the volume flow of the pump, on that engine, with a fully pumpable oil would get oil to the rockers in under 6 seconds, and full oil pressure at 6.
The SAE30 can do that at 30F, the 5W20 at 12 F...so if you were starting at 30F, there would be no difference between any of the "W"s, and the SAE 30.
The next line down, is what I'm assuming is the latter case in my previous description, where the oil is thick enough to open the relief, and not fill the galleries as quickly...i.e. oil pressure is there, but the rocker arm oiling time is doubled.
The SAE 30 is doing that at 20F, the 10W30 at 9F, and the 5W20 at -11F.
Those are still relatively acceptable, but clearly for 0F operation, you would chose the 5W of all of those oils. 5W20/5W30 should not show a difference, as the MRV is the "5W" part, the hot viscosity isn't a factor here(*)...
I don't think a "0W" would do any better than the 5W at filling the galleries...at 0F.
Second part is the CCS, Cold Cranking Simulator, which is a high shear measure designed to test the "startability" of the engine. Basically, the starter motor needs to spin the engine at a speed sufficient for it to go.
Here's some tests
Test engine (the engines behave differently, the Jeep 4.0 seems to be a hard to start machine in papers I've read), different oils, different temperatures, and a bar for easy starting, poor stating, and no starting.
Like the MRV, the different W ratings give the same behaviours, just at different (colder) temperatures.
(*) Note that two 10Ws are tested, a straight 10W, and a 10W30, and true to the "W" grading they are close.
