If all you have in hand is the VOA, then go by that until you have more information to go on. I'd pick the 2nd one which looks like a Pennzoil Ultra type high Calcium oil. The low calcium, TBN and overall detergents in #1 seems somewhat under-powered, probably not as good for longer OCI's. I look at the combined total of Ca, Mg, and Na and normally that runs in the 1,900-2,800 range. This one isn't even at 1800....and the TBN is low for a VOA. Looks like a racing oil while #2 is more for a driver and similar to PUP except for a little less Boron. I prefer the slightly lower 210 deg F viscosity of #2 for a passenger car. If you track the car a lot then maybe #1. Either way I like the #2 package. 60 grade is thick enough....not sure I would need thicker 60 grade as well.
