ronrackley
Thread starter
Originally Posted By: ARCOgraphite
Is that SAE 40 too thick for that GM engine even in FLA? At thickest I would run 10w-30 rotella triple protect with 1 qt sub of Formula Shell 5w-30.
I'm thinking about switching to the new Rotella T5 10w30 [or is it 5w30?] HDEO when I use up the remainder of the 5w40 that I have on hand. It's not that I believe the 40 weight to be necessary or even better for my cars. I only went to the 5w40 to get the stout additive package of an HDEO - which I could only find in 5w40 and 15w40 - when they reformulated the 5w30 and 10w30 oils I had been using for years [Mobil 1] to reduce their ZDDP additive level a few years ago. I just wanted to keep the same basic additive package that oils had when my engines were designed "for good measure," I guess you could say, and the HDEOs gave me that. I ran some 5w40 and got good UOAs and on road trips found the gas mileage to be basically the same - maybe a couple of tenths of a mile per gallon less, at most, as explained in other posts I've made here about that - so I've run with it ever since.
Rotella can be bought in jugs at Walmart at decent prices and, since it has been very good to me, I'll probably stick with the brand and not go looking around.
