Originally Posted By: toneydoc
Leave the oil that is in the truck. It is still fine and does not need changing.
When you get the time and money to change your gasket, then change the oil at the same time. That oil, especially with your top offs, can go til you can get around to the gasket.
Do it yourself and send some pictures of the covers, cams, gaskets, etc when you do the job
+2. In the meantime top it off with the cheapest 10w-30 dino. Since you work at walmart, I'd assume it's supertech dino. BTW, how much of a discount do you get? 30%?
