There is a drain plug that uses the square drive part of a 3/8 ratchet to loosen and tighten. When removed the fluid just clears the plastic undershield. There is a rubber plug that looks like a dipstick but is a rubber plug for servicing under the hood, has a yellow donut on it that says HCF-2. We bought a 2014 Accord EX-L w/CVT for my wife to drive mostly highway miles to/from work. I changed the CVT fluid at 10K, 20K, and 30K miles. That first change, the fluid came out black but still translucent. The second drain/fill was dark but not as dark as the 10K drain/fill. The 30K change looked dark amber; Honda HCF-2 CVT fluid is a golden amber like the color of honey. I got a case of 12 shipped from H and A for $118 and some change. I measured what I took out and refilled with the same amount + 1-2 oz. and did the level check IAW Honda check procedure. (3.7 quarts) Maybe this change sequence sounds over the top for some, but I flushed all the break-in debris out and have nice fresh, stout fluid in there. There were some issues with the 2013's so I wanted to be pro active. Wife likes it...if she is happy, I'm happy; Honda is happy.
