Originally Posted By: Jetronic
get a motorcycle oil maybe? M1 0w-40 might shear down quite a lot, and you definitely don't need the low pour point unless the race is held in antarctica.
Mobil makes a very high HTHS 20w-50 motorcycle oil, I'd add a can of MoS2 or similar and be done with it. API SJ as well, which was current in 1993 I believe. Last oil spec focused on performance, and not emission equipment protection.
The MoS2 or similar is just in case you pull repeatedly high G corners or braking and starve the pickup from oil. I'm guessing no baffled or dry sump.
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-v-twin-motorcycle-oil
Originally Posted By: Joshua_Skinner
Speaking to the topic at hand. The oil isn't going to shear from temperature, but from use. If you want a greater HTHS I would use a 20W-50 motorcycle oil. Mobile 1 V-Twin evidently has a 150° C HTHS of 5.8 cSt.
http://forums.pelicanparts.com/porsche-9...sm-oils-11.html
I'm liking the chorus of "Go Thicker" answers, because by hour 6 of a race with an old BMW, fuel dilution could be heavy. Motorcycle Mobil 1 oil is the best answer for an older engine.
For a tight new engine, M1 0w-40 has been proven:
They trust M1 0w-40 in 24 Hour LeMans GT and IndyCar.
"Porsche 996FL Engine test. This test will last 203 hours. The engine, and the oil, will go through: - 4 times the simulation of 35 hours of summer driving, - 4 times the simulation of 13.5 hours of winter driving, - 40 cold starts, - 5 times the simulation of 1-hour sessions on the “Nürburgring” racetrack, - 3.5 hours of “running-in” program Measurements on the engine and on the oil will be done at regular intervals, and the following parameter will be taken into account to grant the approval or not: - torque curve (internal friction), - oxidation of the oil, - Piston cleanliness and ring sticking, - Valve train wear protection. Cam & tappet wear must be less than 10 µm. - Engine cleanliness and sludge: after 203 hours, no deposits must be visible. - Bearing wear protection: visual rating according to Porsche in-house method."
And M1 0w-40 is factory fill in the Mclaren P1 and Nissan GT-R.
http://share.jayeapps.com/uploads/7afc11...hallenge_JP.PDF
Originally Posted By: oliver88
Interesting. I have seen M1 0w40 being used in Porsche GT3 RSR's and Cup Cars, as well as the Porsche RS Spyder...These are full blown race cars. Indy series uses it as well in their Honda engines.
