Originally Posted By: ChevyBadger
Originally Posted By: A_Harman
Why did he leave out the dilithium crystals?
But anyway, an engine with both a supercharger and turbocharger won't necessarily make any more power than an engine with turbo's alone. When a single stage turbo can boost to ~60psi, there is no need to waste power driving a Roots blower. What a Roots blower can do in such a system is to reduce turbo lag, then it should be clutched off and bypassed after the turbo has lit.
The nitrous would be useful for adding even more power by increasing the proportion of Oxygen in the intake charge.
If he really wanted to know what it would make, it only costs ~$100 to run it on a chassis dyno. My guess is he built it and tried it, but it didn't work.
There is cars built with both blower and turbo. Its called compound boost. The supercharger basically gets the car moving and spools the turbo(s) then it switches over to turbo boost. I am not sure exactly how it works.
Yes, the VW 1.4 TSI had an Eaton supercharger and a turbocharger on it. I worked at Eaton automotive at the time the system was developed, and knew some of the engineers that worked on it. It used a small Eaton supercharger that had 3:1 step-up gears in the front cover, so it would boost the engine HARD from 1000 rpm up to 3500 rpm, at which point, a clutch driving the blower was disengaged, and the turbocharger took over boosting.
