If you keep the car below 30 it doesn't really matter. Tires only have issues from the build up of heat, heat builds up under load or speed.
Why do you think lawn mowers can run around at 5mph all day on 25 year old tires?
Also a tire failure at 25 isn't much of an event, as say a failure at 70. A failure over 100 will get you in the newspaper.
