Looks like I'll be going with one for my 67 f250. All welded aluminum radiators and reasonable price with warranty. Wondering if anyone has experience with them on here though.
I was hoping to hear something like that! They don't list one for a 67 only 68+ but I'm pretty sure 67 radiator is the same. I better do some research before ordering though.
Theres actully 3 or 4 rads for those trucks. 3 inch top tank or 4 inch top tank.straps on front,middle or behind etc.one drawback is that the aluminum ones are not easily repaired.often no good if they leak
Well I put it on but the top hose neck was smaller. 1.75" vs 2" stock. I guess the hose from a "dent side" truck 73-79 with 4" radiator is the right one. I used a flex hose. Kept it classy haha... Works well so far. No leaks and no overheating. I think the radiator I bought is just a bit thinner than stock also. My truck is all stock so I doubt it will have trouble keeping up with cooling needs. Next go around I'll probably get one of the originals repaired and go back to brass/copper more for the original look than anything. But hoping this one lasts. Plus it's lifetime warranty so I guess I couldn't really go wrong.
Mine seems great but it's not as thick as the original so the fan sits too far away for effective cooling at idle. I need a bigger fan spacer or a shroud.
