OVERKILL
$100 Site Donor 2021
HeliCoils hold spark plugs, OK. The website (Stanley Engineered Fastening) lists engine blocks as an application.
I think it would hold fine, but I don't see it happening in any event.
In an iron block they'll hold fine. Aluminum is the concern here.
Maybe. The manufacturer doesn't specifically list head bolt threads, but it doesn't exclude them, either. The cylinder pressures don't pop the spark plug helicoils out. The clamping force on the head is more distributed. I don't see why it wouldn't hold with a HeliCoil.
Regardless, I think this is much ado about nothing. I just don't see it happening under or by OP.
Experience says they are prone to failure. Check out the number of helicoiled Northstar blocks that they pulled out of. They are fine in iron but in Aluminum you want an insert, that's one of the main reasons they exist.
