Hello all. My friend has a 2000 model year Chevy K3500 truck with the 7.4 liter gas engine and automatic transmission.
He started it up normally from cold and drove about 200 feet to where it stalled and would not re-start. It cranks but does not start.
I have checked the following:
Gas tank 1/4 full. He even added some gas to be sure.
He replaced the battery (needlessly of course) before I got there. That was the battery on the right side of the truck. By the way, what does the extra battery on the left side do?
Sparks at 2 of the wires (only 2 tested)
Fuel pressure 59 psi key on, fluctuates around 57 while cranking, drops to 55 key off and holds there for at least a couple of minutes.
No fuses blown either in the underhood box and the one by the driver's door (are there more fuses?)
Code scanner connects to PCM normally and reports no codes are stored. I cranked for about 20 seconds constant to try and retrigger any codes that might have been erased when the battery was removed.
Live data from code scanner reports seemingly sane readings from all the major sensors:
Engine rpm: 0 when not cranking, 190 while cranking. (I assume this is from the CKP?)
IAT and ECT: about 60 degrees F, which is ambient here.
MAP: 28 inHg not cranking 27 while cranking.
MAF: 0.3 lb/min not cranking about 1.0 cranking.
TPS: 0 to 100 smoothly varies with throttle position.
So this fine American machine should start right up, right?
