I think you will enjoy it. My El Camino was built with a 305 and a 3-row copper/brass radiator that eventually deteriorated, and over time it became impossible to find a new one like that, without spending several hundred dollars, so I ended up with the one-row aluminum/plastic replacement that's purported to be an exact substitute.
With the new 350, I never was happy with the aluminum/plastic stock replacement (never overheated, but ran a little warmer than I like), so I found an all-aluminum radiator with two 1" rows. I forget where I found it, but it cost about 1/3 of the big name brands, and I've been very happy with it. It runs cooler than with the aluminum/plastic "stock" joke of a replacement, even when it's 105 F with the A/C on. The hottest I ever see on the gauge is about the point where the thermostat is fully open (210 or so F; I use a 195 F 'stat), so the radiator's able to handle all weather and whatever I ask the engine to do.
The best part is, it fit in the same radiator shroud, so I didn't have to modify anything at all. Pretty good deal for a noticeable performance improvement without having to hack anything.
