Agreed. Easy enough to manage but that's not the issue. As minimal as you've pointed out, two oz. is a fair percentage of the 12 oz. of oil in the sump. Using two to three oz. ever 25 hours or so will cause the low oil level switch to shut the generator of at around 65 to 70 hours. Not something that I like to see. Accordingly, I usually top off the oil ever 30 hours or less. I've never had any engine use oil before, let alone a quality piece like a Yamaha? However, other than my Kubota diesel engine, I don't use other engines for five to six hours a day, five days of the week. Nonetheless, others have reported running their generators for long hours with little to no oil consumption.
I did an oil change on it this last week. For this time of year (fall), I like to use a blend of 5W30 Rotella with 15W40 Rotella. I'll have to see if that makes any difference. I kind of doubt that it will.
Originally Posted By: andyd
2 oz? That is like 4 tablespoons. That is easily managed. A tad low tells me the oil isn't gassed very much. Keep an eye on the oil level as you should with all OPE.
