Dirty_Howie
Thread starter
Originally Posted By: CT8
you will not know unless you try thicker oil. You don't need the 0W part unless you are starting up in below 0*f temps. If you want to Stay with redline try 10w-40. 15w-50 M1. Maybe 20w-50 Mobil1 motorcycle oil. You want to run the thinnest oil as not to cost you horse power yet thick enough to protect the engine when you pound on it.
Whether he needs the 0w-xx part of it or not I believe GM runs M1 0w-40 in their own Track Program Corvette's so I don't think recommending it for this application is unusual.
This is what GM puts in the european Z06 version (same engine)
DH
DH
