Both my VW and Bmw diesels have not had the lubrication of the safety/emissions defeat switch done.
This is needed about every year or 12,000 miles, as the defeat switch operates everytime the car is driven here in the USA.
Do I need to use a German specification lube for this? or is there a USA source (maybe maxlife?)
And what does BMW specify- what is the Factory spec, and is it a dealer only item? Someone on the BMW forum said spraying it with wd40 would void the warranty.
For the BMW, if you lubricate or replace the switch do you have to have the dealer re register the switch?
