Hi all, been researching aftermarket oil filters for my 2004 Polaris Sportsman 500. I like the Wix # 51358. Per Wix, the max flow rate is 8-10 GPM, burst pressure is 265 and anti drain valve setting is 8 psi. How does this compare to the OEM Polaris filter? I know it uses a dry sump system and I heard talk that OEM is required due to certain flow rates etc....
