Plenty of pictures on the net about Dexcool sludge that looks just like the video. I guess some of you think that all the pictures are fake.
GM starting using Dexcool in 1996. Ford starting using it when? I think it was around 2011. There was a good reason Ford waited to use it, and used G-05 for a number of years. Same with Chrysler. Chrysler said that there was a problem with Dexcool and solders in heater cores.
And to who ever else comes across this post. Prestone all makes and all models antifreeze still contains 2-eha. The latest stuff with corguard still contains 2-eha. It is just a Dexcool clone, so please don't use it if your car is not spec for it.
Peak long life is a Dexcool clone too, and it contains 2-eha. Peak Global, while being an OAT coolant like Dexcool, it does not contain 2-eha.
To anybody that wants to question my judgement. I had a GM 1998 Malibu that I bought new with the factory fill Dexcool. It had two leaking lower intake manifold gaskets before it got to 100k miles. Yes those were plastic gaskets. I also experienced the Dexcool sludging , but I am OCD on car maintenance, so I caught the problem early, and changed the Dexcool with fresh Dexcool. If I had known what I know now, I would have definitely used regular green in it.
Anyway, I think the Dexcool problems are history because of automobile manufacturing changes, but please don't pretend that they never happened.
