Quote:
A particle streak occurs when a very small piece of dirt gets lodged in the bearings and spins around, gouging out a streak of lead, before becoming dislodged. A particle streak will cause a temporary increase in lead, and then once the dirt leaves the system, lead drops back down. To see a picture of a bearing that has experienced this phenomenon,
^ This is a quote directly from blackstones website.
