As I had posted a few days before, I bought a 2001 Ranger 5 speed with the 3.0 Vulcan 132k miles that needed some TLC. Things Ive done so far:
oil change (Motorcraft 5W30 syn blend and a Motorcraft FL400S filter, i plan on 5k ocis, do i need to worry about the puro tearing issues with these?)
new Wix air filter
upper and lower ball joints and sway bar end links and brake pads
tires rotated and lugs torqued to the proper 100 foot pounds
flushed out cooling system and filled with Prestone 50/50
Things to be done within the next month:
New Motorcraft camshaft synchronizer (starting to make the chirping noise)
new serpentine belt
new thermostat (engine is very slow to warm up)
PCV valve
drain and refill the 5 speed(not sure which fluid it takes)
new fuel filter
rear end drain and refill
power steering, brake and clutch fluid look ok but ill be changing that soon as well
Does it seem like i have most everything covered guys?
I want to keep it up as best as i can, it will be driven 7 days a week, 3 weeks at a time for work, 44 miles a day, which may not seem like much but ill be using it alot on my days off.
new Wix air filter
new serpentine belt
PCV valve
new fuel filter
