it's not MoS2, and if your turbo survived a couple of hundred miles without proper oiling I believe you have the MoS2 to thank.
Originally Posted By: Jetronic
Originally Posted By: Torres
Well I cant say if for sure, but the oil pressure light stops each time I change the filter. And at idle the light gos off..., only it shows when its over 1500rpms.
That's a key bit of information right there. And it's telling me you have oil supply problems. If you get low oil pressure at higher rpm only, investigate the oil pickup screen as it's likely clogged. Drop the oil pan.
I bet that's what killed the turbo in the first place!
