Originally Posted By: HTSS_TR
Two questions:
Fog light is not standard equipment for your Accord, you added aftermarket fog light ?
The color of the front bumper is a little odd, the center has different color then the outsides ?
Correct. On the 2008-2012 Accord 4cyl sedans, fog lights are not standard equipment, however, on the EX and up sedans, there is ready to go, plug and play wiring behind the bumper cover. On every 4cyl sedan, you have to remove the bumper, cut out and mount the fog lights, housings and trim pieces. Being that I had an LX, I had to make a custom wiring harness as well and wire it up. Has worked well for over a year and did fine with the winter so I must've done a good job.
The bumper color is lighting playing tricks, its all the same color. That and the car can badly use a wash.
Two questions:
