I've been doing some thinking about extended oil change intervals. In particular, I am wondering what is the real cost of extending the OCI. For example, Amsoil will compare 25,000 miles on conventional oil and regular filters, to 25,000 miles with their Signature Series, and one Ea filter.
Basically, it comes down to 40 quarts of the conventional oil and 8 conventional filters, vs 5 quarts of the Signature Series oil, and one Ea filter. The latter ends up being a fair bit cheaper over all.
But what they don't talk about is used oil analysis. Would you really just pour in the Signature Series oil, screw on an Ea filter, and drive it for a year or 25,000 miles? In my mind (and I could be totally wrong, hence this post), I would not be comfortable going much past the manufacturer's recommended OCI, without some sort of regular oil analysis. But if I am doing some regular analysis, the cost of the extended OCI isn't quite as cheap, because the oil analysis adds up.
In any case, I am not hating on Amsoil here - I like the company, and I think they have good products. What I am after is some real figures on extended OCI. How much UOA is necessary? When would I take the first sample? How often afterward? Hopefully I can get a handle on the true cost of running an extended OCI.
