Hello
My pickup started having climate control problems. The dampers would modulate to defrost when engine loaded, then back to the setting when coasting. In time they just stay in defrost position. Now, the heat comes on and off by itself, even though calling for A/C. I can see condensate dripping out. I checked the refrigerant pressure, and they seem pretty close to parameters I read about here. I do commercial refrigeration, heating and A/C.
The 4 wheel drive partly engages and makes noise and sort of locks up, it took some gas peddle and brake to get it to fully disengage.
Is there a connection with the two issues?
Thank you for your time.
