BOBISTHEOILGUY
Thread starter
David, I think there are several things missed on this, try running your engine oil drain out to 28,000 miles on a motor with approx same miles as this one, then look at the numbers.quote:
Originally posted by davidc:
Hey guys, how many of you commenting actually "own" a Cummins Turbo Diesel?
I do and have since 1990.
Those Iron numbers are high compared to my 13 year experience with my two trucks.
I averaged 20-25 ppm iron on 12000 drains intervals on my first truck and now 35-45 ppm on my current truck with 147K on it. This was using standrad full flow filters.
I think those iron numbers are high.
I think you're not comparing apples to apples here with such a difference in mileage. Also, not all engines are going to wear the same, as some may think. You can have an engine that has consistant higher wear numbers no matter what you do such as the ls1. But in comparision to the previous drains, you can see an improvement. Thats the reason for a trend analysis on that one vehicle where you can establish the norm for that engine and tell if you are having improvements in what you are doing.
[ July 24, 2003, 10:37 PM: Message edited by: BOBISTHEOILGUY ]
