Hopefully, the pics will save a few thousand words!
General info:
- We live in a rural area, not convenient to take rotors in to an auto parts, yet I like to have a fresh finish for new pads. Please note that since I usually don't run rotors to the core, I'm not talking about cutting them.
- I used a 1/3 hp 115/230v 1750 rpm bought new on ebay for about $40. The 1750 is a bit fast but it still works fine.
- Turntable that the rotor rests on is intended to take weight off of the motor. Came from McMaster-Carr.
- Motor is mounted on unistrut to allow it to slide to adjust bolt plate to mount to rotor.
- Frame is made from some scrap angle and a couple pieces of plywood.
- Studs are not on a dead-centered bolt circle so the rotor will wobble a bit when turning but has not been an issue.
- To use, I flip the switch, rotor spins. While it spins I take a drill with the hone brush and apply to the spinning rotor with a little back and forth motion. Only takes a few minutes per surface to get a decent fresh finish.
- Checking rotor thickness with a dial caliper shows negligible material removal.
- I've used it twice with good results. We have enough cars/trucks in the family and it was cheap enough to build that I figured it to be feasible and easy to build project.
General info:
