Originally Posted By: Shannow
Originally Posted By: Miller88
Originally Posted By: bullwinkle
Wow-12 to 14 MINUTES for rocker arm lubrication on a cold 6.2 (assuming also 6.5)!?! Sounds like a serious case for 0W30, or at least 10W30, in extreme cold. The 10W30 T5 that I ran in my 6.2 last year made a big difference in cold crank speed-but it didn't get to -15F, either.
A 6.2 has to crank for 20-30 minutes in the cold to get it to start (if it starts). Does that mean it's already lubricating by the time it finally starts?
No, the engines were cranked via an external drive from another engine at the limits of pumpability of the oils (they chilled them to find the limits)...engine had the injectors disabled so it COULDN'T start.
Army was testing the limits of pumpability of their oils in their typical engines.
Can actually gather the most from the paper by reading it.
You missed the joke there
The 6.2L diesels are extremely cold blooded and often refuse to start at all once the temperature gets anywhere near or below freezing.
