If you go to Denmark, you will probably go to Copenhagen.
If you go to Copenhagen, you may well go to Tivoli Gardens (Walt Disney's inspiration for Disneyland)
If you go to Tivoli, might dine at Groften* (the ditch) the oldest restaurant in Copenhagen.
If you dine at Groften you could order their Skipperlabskovs (Afterall, they do serve upto 50 TONS of the stuff each season)
What is Skipperlabskovs?
Back in the old days, say you are a Viking having sailed the North Sea after a hard week of Rape and Pillaging, you come home to the Mead house and......
Well little open top sandwiches are not going to cut it.
You need a pile of Skipperlabskovs, or by the time the dish was brought over to the U.S.
it had morphed into Beef Hash.
But as in so many cases, I think the original is MUCH better
Skipperlabskovs or sailor’s beef stew
1 pound well-trimmed stewing beef, cut into ¾-inch cubes
1 ¼ cups beef stock or bouillon (or water)
1 large onion, chopped
3-4 bay leaves
15 white peppercorns
2 ¼ pounds potatoes, peeled and sliced
Salt to taste
Chives for garnish
Pickled beets
Blanch beef cubes in stock, bouillon or water, add onion, bay leaves, and peppercorns, and boil for an hour, adding more liquid as necessary to keep the ingredients covered.
Add potatoes and boil for an additional hour. Discard bay leaves. Mash the potatoes and meat lightly with a whisk, blend well and salt to taste. The consistency should be like porridge. If it is too firm, add a bit more liquid. Serve with a generous amount of chopped chives on top and a dish of chopped pickled beets on the side.
Serve with several beers and Akvivit Shnaps.
*If you go to Groften check out the washrooms, they are arguably the best in Europe!
3-4 bay leaves
Salt to taste
Chives for garnish
Pickled beets
